Error code Oce CS650 / KN CS6500 - code C-0213
  • Escape_All
    [Error Code] Error code Oce CS650 / KN CS6500 - code C-0213
    I read a topic of this error code, but it didn't solve my problem.
    The machine still falls back in thous error code after printing one sheet.
    We have switched the complete fuser for an other one.
    Is it possible that the issue is somewhere else in the machine?
    Thanks in advance.
  • Mick01
    • Nov 2012
    • 362
    Re: Error code Oce CS650 / KN CS6500 - code C-0213
    Your issue is with the "Paper Exit Unit" not the fusing unit. There are two one way gears that slip that will cause this error. Remove the finisher, remove the left side panel, remove the paper exit unit, replace the two gears.
    hope this helps
