Develop Ineo +220 (Konica) C220
  • CrapAimer
    • 296
    Hi all
    Just wondering if anyone has come across this fault, The paper is going in squint when using tray 1 but works fine with tray 2 ?
  • habik
    • 2013
    Re: Develop Ineo +220 (Konica) C220
    Check the vertical paper guide, they tend to pop out due to incorrect paper jam removal OR separation tyre is warrrped aor worn to one side, usually damaged by mylar on paper cassette RH side. i tend to trim them in 45 degree angle
    Firmwares HERE
      • 14916
      Not sure what "going in squint" means, but, if you mean it is skewing, then you need to concentrate on the 1st tray and feed feed assembly. Make sure the guides are straight and against the paper. Check for any burrs or damaged mylars in the paper path. The feed assembly is easy to remove.
      Hope this helps
      Darren
