Bizhub C353 prints only half page
  • copyline
    • Feb 2012
    • 11
    I withdrew a C353 as a result of a problem with the black drum. Now the machine prints only half page in black and white and offsets all colors. I tried to change black drum, black laser and PWB. Can you help me?
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Bizhub C353 prints only half page
    post a sample.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
        • 23010
        Post a sample. What leads you to believe that it's a black drum issue? =^..^=
        • copyline
          • Feb 2012
          • 11
          Here a color sample and a black and white page
          SKMBT_C35313121310010.pdf
          In a machine control we noticed that the black imaging unit was losing a lot of black toner that we found inside and on the laser unit. So we replaced black imaging unit and tried to clean laser.
          Machine status was p6 and p21 and it was printing only half page.
          Then we tried to replace black laser unit, Cyano imaging unit, belt and last PWB.
          In Service Mode I can't perform Stabilizer under Image Process Adjustment - Gradiation adjustment
          Thanks for your help
          • copyline
            • Feb 2012
            • 11
            While I was writing the list of changed parts I noticed that the laser cyano had not been changed. So I proceeded and I took off and put back the black laser unit. Now it's alright. Thanks
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              indeed, that image uploaded looked a hell of a lot like a severely crooked black print head.
                • 23010
                Congratulations on your success. =^..^=
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  It had been almost a year between laser replacements for me.
                  I got to do one recently, all I could remember was it's a pain to do with the finisher, so I was pleased to see no finisher.
                  I accessed the printhead no problem, but struggled to get it in and out.
                  Checking gradation afterwards I said "damn I need to come back with a t-belt", it's dented and smudged.
                  Two days later, I awoke in my sleep. Oh, crap the dents and smudges were because I didn't remove the t-belt.
                  Doh!
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    you can still do it easily with the finisher remaining installed.
                    Although totally unacceptable as far as the service manual is concerned, it is possible to remove the front panel with minimal disassembly if your prepared to "flex" the rules a bit
                    • copyline
                      • Feb 2012
                      • 11
                      Now there is another problem. I put the original PWB, thinking that wasn't the problem, and now the machine will stop with the error C-3101. I tried to change fuser unit without getting results. Do you think can I make other attempts before putting a new PWB?
