can isopropyl alcohol be used for safely cleaning drums
  • kowloonkid
    • Oct 2013
    • 6
    [Misc] can isopropyl alcohol be used for safely cleaning drums
    Hi guys, can someone tell me if i can use isopropyl alchohol to safely clean the drums on my konica minolt
    a c5500?
  • seeb
    • Nov 2009
    • 41
    Re: can isopropyl alcohol be used for safely cleaning drums
    I have done it many times with no apparent side effects.
    • kowloonkid
      • Oct 2013
      • 6
      thanks for a quick reply!
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        a c5500?
        I don't work on the KM machines, But on the Ricoh's sharps ect. I'll use it to get sticky stuff off the drum. To clean and polish a drum I use NUFINISH car wax, also on Ricoh's hard charge rollers..
        Mystic Crystal Revelations
        • JR2ALTA
          • Feb 2010
          • 2033
          Alcohol is fine, just careful your rag isn't abrasive
            • 23009
            Yes.
            Other choices that do not damage drum coatings:
            Dispersant
            Paraffin Lamp Oil
            Orange-Sol
            But all these cleaners are oily so you need to rinse the drum with alcohol when you're done. And I'm beginning to think that the Paraffin can absorb into polyurethane ... like drum blades, so make sure Paraffin does not contact the drum blade. =^..^=
            • wseyller
              • Sep 2012
              • 1129
              Depends on the drum. Years ago I used to recoat drums and some of them would crystalize after time when apply isoproply to them. Normally those particular drums were crap anyway.
              Sent from my DROID BIONIC using Tapatalk
              • CompyTech
                Super Tech
                • Feb 2011
                • 706
                I've cleaned them with alcohol before. I've also used brillianize before.
                • Phrag
                  • Oct 2012
                  • 417
                  I used Rum- I mean ALCOHOL to clean off tape residue from a brand new C452 transfer belt. Nice packing KM.
                  • Synaux
                    • Mar 2012
                    • 1224
                    Yes.
                    Dispersant
                    Paraffin Lamp Oil
                    Orange-Sol
                    I agree with the Paraffin--in the past, I have actually researched paraffin while fabricating a surfboard--its applications are vast and might surprise.
                    Anyways, regardless of safely applying anything to the drum, one should ensure that little/no reside will reach the blade.
                    • Ray G.
                      • Sep 2008
                      • 22
                      No problem on the alcohol, but do remember to use a lot of padding powder.
                      • mitchl
                        • Apr 2007
                        • 501
                        Alcohol is fine just make sure its 99% isopropyl.
