Konica Minolta C 353 Fuser Roller Issue
  • junidexy
    • Sep 2013
    • 32
    I have a issue, My Fuser Unit Fuser roller got Damaged, what might cause this problem, any body help me, image is attached in this
  • Synaux
    • Mar 2012
    • 1224
    Re: Konica Minolta C 353 Fuser Roller Issue
    Ouch, there is an updated firmware for temp to help avoid damage to the fuser. Also, make sure sleep mode is enabled.
    • JustManuals
      • Jan 2006
      • 9838
      I have this firmware, email me if interested in purchasing it.
      Paul@justmanuals.com
      • jotunn
        • 595
        Time makes this - this is known issue with machines or fusing units kept unused for a long time (year or so).
        • methogod
          • Dec 2008
          • 916
          all of the Konica business line is not made to be READY to use at all times. I would set it to SLEEP after 3 minutes, so that it powers off, they all warm up so fast, that cost of parts is not worth that few seconds it takes to wake up...
          in fact some of the newer ones have motion sensors so when your walking up to it you can set it to make (C554 series)...
          change fuser
          set lowpower to 1 minute, sleep to 5 minutes.
          or less...
          should last longer...
