C450
  • sunsetoutpost
    • Nov 2009
    • 54
    C450
    Top half if image is side one (prints clean), bottom half is second side (pinholes in halftone areas). This happens in black only and color. Tried different paper stock, no change. -- HELP!
  • JustManuals
    • Jan 2006
    • 9838
    Re: C450
    Paul@justmanuals.com
    • blaze2000
      • Sep 2010
      • 232
      Re: C450
      Transfer voltage adjustments, check them make sure all your adjustments are at default.
      • sunsetoutpost
        • Nov 2009
        • 54
        Re: C450
        OK -- Changed the 2nd transfer roller, reset transfer adjustments, cleaned sensors, no more pin holes in the non-solids. Now, only on the second side, and only in the black image I'm getting this. I know it's New Year's Eve, I'll get my bubbles later!
        Tried to replace the black IU, but got 'wrong IU installed' error and had to put the original back temporarily.
        • Albonline
          • Sep 2008
          • 1151
          Re: C450
          [ATTACH=CONFIG]23458[/ATTACH]
          this is a lack of humidity issue your 2nd transfer settings should take care of this, however there is a high altitude setting you can try. setting this makes doing gradation impossible.
