Hello there guys.
I was curious to see whether any of you ever encountered this one on a bizhub machine.
Machine works fine aside from the messed up screen.
Steps taken to try to find out the origin (without success):
- Replace entire operation panel with a working one from another machine;
- Disconnect all peripherals
- Update firmware
- NVRAM Restore
- Check panel cable continuity
- Clean memory DIMMs
- Swap memory DIMMs
- Use only one DIMM on the bottom socket
- Disconnect HD
- Remove NVRAM (machine will hang at the sandclock, but screen still garbled)
Any tips are welcome!
Happy 2014!
- Update firmware
- NVRAM Restore
- Swap memory DIMMs
- Disconnect HD
Happy 2014!
