Used c352 Advice
  • newrome
    Used c352 Advice
    Hey Guys,
    I haven't posted on here in about forever and I guess my username got cleaned out...
    I am looking for a little expert advice...for a 100% Canon user...
    I am thinking of picking up a used C352 for home...need the scanner for a project and the office is 5 miles
    away and I am too lazy to go back and forth...
    Found a C352 for sale that has about 300k clicks and has been serviced regularly...the current complaint on the machine is
    that it is producing some dog-eared copies every once in a while...some wrinkles also. I noticed that the
    low-power / sleep settings were set to 240min! I am thinking that it is probably the fuser, but did not
    visualize any bubbles...Their contracted techs claimed they could not find anything wrong with the machine...blah blah...
    only doing the dog-ears 1% of the time...yadda..yadda... I ran it...and from cold it was copying fine.
    Anyways...the thing is $500 w/ internal / external finisher.
    I am a handy, can pretty much fix anything with a manual and have worked on many lasers, large and small...but haven't serviced a copier.
    So you Konica guys...what do you think?
  • JustManuals
    • Jan 2006
    • 9838
    Re: Used c352 Advice
    Paul@justmanuals.com
    • solidzdawg
      • 71
      Thats cheap considering the price...
      did you manage to check the life of anything else? Imaging units, transfer belt, fusing unit, etc.
      Sounds pretty swell, but i am not an expert (yet!)
      Routine maintenance isnt difficult to learn, service manual is a big chunk of information, though there is a quite a bit not in any manual....
      I wonder what the real experts will tell you...
      -Z
      • emujo
        • Jun 2009
        • 3009
        The only thing that would give me pause is the MFP is considered obsolete. Driver availability and scanning options may be limited soon. All consumables are units (fuser, x-fer belt, IUs) so they are expensive, but easy to swap out. Emujo
          • 23002
          The fuser could account for both dog-eared corners, and pin wrinkles. You could pay another $400 for the fuser. It's a not difficult to change. If I remember correctly there is a hidden connecter under the little front cover, under the panel. =^..^=
