Konica Minolta Scan Copier Issue
  • junidexy
    • Sep 2013
    • 32
    I have Konica Minolta C353 Copier, Copier Print are fine, also Photcopy from RADF also fine, when I keep paper in the Glass and got photocopy it has light shadow in the corner, I attached all the image, anyone can help me on this
  • gurko_gg
    Prod.Line Technician
    • Sep 2011
    • 43
    Re: Konica Minolta Scan Copier Issue
    Hi,
    You should be check radf's hinges
    Regards
    • JR2ALTA
      • Feb 2010
      • 2033
      Increase edge erase in scan settings, set as default when shadow is gone.
      • emujo
        • Jun 2009
        • 3009
        That's cheating, but I like it...Emujo
        • Imsdal
          • Aug 2009
          • 111
          Clean the mirrors and under the glass.
          • 907tec
            • 434
            We have seen the same defect occur when the scanner frame is bent, or if the scan mirrors are not aligned properly.. Sometimes people lean on the free-hanging left corner of the scanner assembly, causing it to sag downwards. Take a step back and look at the front lip of the scanner assembly to make sure it is perfectly level.
              • 23010
              Originally posted by gurko_gg
              Hi,
              Regards
              I'm with gurko on this one. Most likely the document feeder height is too high at the rear. It could be a height adjustment, or the hinges may be worn out. It's unlikely to be a bent scanner frame since you would get parallelogrammed scans from both the glass and the document feeder.
              The shading that you're seeing from the glass is just that the paper is not being held down to the glass. A simple test would be to place your original on the glass, then place a ream of paper on top of it. My guess is the shading will be gone.
              Good investigating. There are enough clues in these documents to give a definitive diagnosis. =^..^=
