bizhub 350 faxing 0x0000999a
  • brent
    • Nov 2008
    • 1208
    bizhub 350 sits there and it aborts. either faxing or printing it will just abort. I replace the mfbs board. that did not fix
    I initialized then did a total reset. nothing. I have the fax board disconected. it still did it. the service book is not
    really clear but it said replace the mfbs board and the fax board. any thooughts>?
    I think the code I stated is correct. hard to make it do it and record the code. thanks
    brent
  • wseyller
    • Sep 2012
    • 1129
    There is a special firmware that is available that will help with these 999a abort codes. I have correct the issue a few times with it. Firmware A11U-0100-H12-08-002
    Sent from my DROID BIONIC using Tapatalk
    • brent
      • Nov 2008
      • 1208
      Re: bizhub 350 faxing 0x0000999a
      I just got a 421 firmware updated the other day. I need to take a look and I will do it.
      thanks a mill
      brent
      • wseyller
        • Sep 2012
        • 1129
        And also I will mention that it is aborting probably due to a print job in a print queue somewhere that the copier can't handle. Usually disconnecting the network cable will keep it from aborting. The firmware allow the copier to accept the job.
        • brent
          • Nov 2008
          • 1208
          upon closer look. I have seen this code before as well. I went and got my flash drive to upload firmware. and guess what. it takes a different type of card. I have the flash drive. and then the older minolta card for the cf 2001 but it takes a special card I guess.
          I downloaded the manual and am looking. I am kind of stuck on how to get a card
          and the utility to do such.
          thanks for the help
          brent
          • brent
            • Nov 2008
            • 1208
            also. Idid see a print job coming in. is it more of a stuck job or a certain type of operating system? how does one
            figure out what computer its coming from on the network. is it possible? I appreciate all the help
            brent
            • brent
              • Nov 2008
              • 1208
              I just got back from the account. something interesting.. I say.. happened..
              its always the copiers fault right? ha anyways. they have another identical bizhub 350 they hooked it up and within 5 minutes. boom it had the same code. so I talked to the administrator and told him there was something probably knocking it out. in print que. he is going to use a shark something. and watch the packets come in tomorrow..
              also Ihooked the original copier up. the one this post is about. as a fax and copier. no ethernet connection. and it doesnt' abort out. so. I think were onto something here
              I reallly appreciate all the help on this
              brent
              • wseyller
                • Sep 2012
                • 1129
                The program is wire shark. Very useful tool. They could use it to see anything going to the Mac address of the copier. The packets of that information could then show what computer it came from.
                The copier uses a normal cf card. Unlike some other models the formatting of the card can just be a basic fat32 format. When you extract the firmware you get about 7 files I think. Just drop the files on the root of the card. Put the card in with machine powered off then boot it up. Also I would remove the cat5 cable before updating.
                Usually after firmware fix the job that caused the mess will start printing out.
                  • 14347
                  The CF card needed can't be any bigger than 256mb. Wseyller is correct in that there is no special utility needed to write the card. Just highlight files and send to the card.
                  • wseyller
                    • Sep 2012
                    • 1129
                    I believe the size of the card does matter. Though my company only supplied me with two 512MB cf cards. It does not work for any models that requires firmware imaging toolkit but for models like the bizhub 350 my 512MB sandisk does indeed work very well.
                    Every time I need a cf card for firmware imaging toolkit I have to borrow one from a tech that has a good one they've had from 10 years ago. Lately though I've setup my laptop with ftp utility and tried to do away with cf cards.
                      • 14347
                      I use a 128mb card, but, any 512mb cards I have tried have failed and I have tried several different brands with the bh350 line.
                      • wseyller
                        • Sep 2012
                        • 1129
                        Yeah I think it his hit or miss. But I swear my 512 has worked flawless on bizhub 200/250/350 series and 222/282/362. Only on these models does my card work.
                        • brent
                          • Nov 2008
                          • 1208
                          Had a talk with the administrator and they traced it down to a dictation machine sending a bad print job to this machine. Thanks again to all who helped
                          Brent
                          • lv2fix
                            • 2
                            Here's the problem and fix after 1 month and several bizhub 200/250/350/423 and more.
                            Started with Vista and Windows 7 drivers.
                            The copier is confused and aborts every 3.5 minutes.
                            Someone added a new PC, laptop or reinstalled a driver.
                            Unfortunately you have to hunt down the offending print queue.
                            May have to delete driver and reinstall.
                            May have to restart PC to delete or reinstall driver.
                            The SNMP and Auto configuration of options in the driver is causing chit chat which interferes with print jobs.
                            "Uncheck" SNMP box in print driver located in PORT Configuration.
                            Also uncheck "auto" box for machine configuration (automatically configures options).
                            Tried boards and firmware with no success.
                            I had to change the copier nic IP Address and go to each PC until the offending PC was found.
                            Customer swore that nothing changed and its the machine.
                            I configure all drivers to Port 9100, "uncheck" SNMP and AUTO configuration.
                            • brent
                              • Nov 2008
                              • 1208
                              This is all such good info. In my case. They actually found the unit sending crappy info to the printer. It was an old dictation unit. I'm glad they found it
