C253
  • CrapAimer
    • 296
    [Error Code] C253
    Hi
    Have a C253 with a laser fault code on it. says to replace the PH unit I have an old machine can you just replace the faulty unit (magenta) or do you have to replace all 4 ?
    Regards
    George
    • 23008
    Re: C253
    I can answer this one based on other posts I've read.
    Konica Minolta says that they must be replaced as a set. In real life, if the laser unit calibration is close enough it will work to replace a single. Odds 3/4 in your favor. =^..^=
    • gurko_gg
      Prod.Line Technician
      • Sep 2011
      • 43
