Konica 7055 error f36-2
  • tonyadf
    • Aug 2025
    Ive got error f36-2 on a Konica 7055 copier.
    The thermisters, thermal fuses and lamps are ok so I thought it would be a reset job.
    Ive tried dip sw 3-1 but I may not be entering the command properly.
    Haven't got much info on Konica as I usually look after Ricoh kit.
    I would appreciate help from anyone who is more familiar with these copiers.
    Thanks guys. Tony.
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    I personally do not work on that model, but I do work on other Konica models. I searched Konica's site and found a couple of things. One is the correct procedure to reset the fuser codes and the other is dealing with intermittent 36-02 codes. Hope this helps.
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
    • laserman06
      • Dec 2007
      • 323
      OOPs, forgot to attach the files. So here they are.
      Ps 46:10
      • tonyadf
        Konica
        Many thanks for the manual page, everything reset perfectly.
        Tony.
        • glauberstedile
          Konica 7022
          Ive got error f36-2 on a Konica 7022 copier.
          The thermisters, thermal fuses and lamps are ok so I don't kwon as do it.
          At the others manufacturers have as reset this problem.
          Thanks guys. Glauber.
          • tonyadf
            konica reset
            Konica 7055 reset. may be the same as yours
            Tony
            • redhotrob
              • 69
              With your 7022, or any machine in this series, all you need to do is touch those darn temperature sensors on the heat roller for them to act up. When I did service those models, I always carried a set of the sensors in my trunk stock. It got to the point that I wouldn't want to change the heat roller or clean the sensors without having a spare in my car.
              • glauberstedile
                Thanks, That's ok.
                • chejay127
                  • Jan 2011
                  • 42
                  Re: Thanks
                  Originally posted by glauberstedile
                  Thanks, That's ok.
                  Sir I am also having this kind of error code, i did try to reset those codes to zero then turn off the machine, when i power on the copier the error is gone and it will warm up for a few minutes but when I hit print it wont make a copy but display the same error code which is f36-2.. please help..
