2014-01-14 17.15.39.jpgcan one of you great gurus give me some insight , its only the black that does this. much appreciated!
Strange banding along the side
Re: Strange banding along the side
I'm going to make some WAG's that this is a copy, not a print, and from the glass, not through the document feeder ... true?
If true, the document feeder height may be out of adjustment, letting the original float up above the surface of the glass. =^..^=If you'd like a serious answer to your request:
Yea, or perhaps a mirror in the scanner is out of place or bent housing.Comment
You think? You're asking for help and you haven't even determined what model it is? =^..^=If you'd like a serious answer to your request:
this is on a konica minolta c5500, not sure what the problem could be it's kinda intermittent , sometimes when i change the paper size i don't see any black toner residue. transfer belt issue or a drum blade problem?
