Need to rebuild Creo IC-304
  • CluelessPrinter
    • Jul 2012
    • 5
    [Dead] Need to rebuild Creo IC-304
    I just bought a used KM C6500 with Creo IC-304 controller. Controller won't boot. It gets to the XP splash screen and then goes back to bios. I don't have the install disks for XP and whatever other software is installed. Are the downloads available somewhere?
    Thanks,
    Tim
  • Synaux
    • Mar 2012
    • 1224
    Re: Need to rebuild Creo IC-304
    Thanks,
    Tim
    The OS for the Fiery is proprietary so you need to be a licensed technician or know one to attain it (or buy it). I am sure Justmanuals will post here soon.
    You might wanted to start by doing some routine computer diagnostics--check memory, HDD, reseat CPU clean and apply new thermal paste (sounds like it could be overheating), check for bad capacitors on the mainboard, et cetera. I have had this happen with computers where the reset or power switch is faulty too.
    • dljorg
      • Sep 2009
      • 93
      To be clear... IC-304 is a Creo controller NOT a Fiery. Does the same stuff, different manufacturer.
      Creo has three disk drives, kind of a RAID arrangement and it looks like from your description that one of the drives failed. Replacing the drive is not a big problem, just be sure you get one the same size and speed as the one you take out.
      Software will be a problem. You need the original system disks. Disk 1 is the Windows operating system, different than regular XP its been customized for use in the Creo. Disk 2 is the Creo RIP software. KM has the stuff posted on a service rep only website but there does not seem to be any other source.
      Creo is /was an Israeli company that had some hard times in the last economic slowdown. I believe that they have been sold to Kodak but not sure about that; in any case finding support is questionable. Have tried to get newer drivers for Creo controllers but KM is the only place I have been able to find them.
      Sorry I can't be more help.
      • zietha
        Thanks,
        Tim
        I can help you if you live in Vietnam
