C451 has light shadow print out while doing double-sided (Mono only)
  • brianho80
    • Sep 2009
    • 198
    Hi guys,
    Anyone of you familiar to this problem before?
    At the beginning, I try to service (k) drum unit, clean up developer, drum, blade and contact points but problems remain the same..
    Second attend, I replaced (k) IU unit, hopefully can solved but no luck. There after, i suspect transfer roller and replace with another used unit (good unit), however problem remains the same.
    lastly, I access service mode, change transfer value setting by adding it. Shadow had gone and my print out didnt effect much like blur or having background.
    Anyone has better solution or know the why??
    Aprreciate for your sharing..
  • Albonline
    • Sep 2008
    • 1151
    Re: C451 has light shadow print out while doing double-sided (Mono only)
    did you jam the machine and look at the print before it went through the fixing unit?
    • Synaux
      • Mar 2012
      • 1224
      Do you have the guide sheet mod installed? a00h 7034 00
      • brianho80
        • Sep 2009
        • 198
        Yes ... I did make it jam n check drum image. Can see image print on drum with very light d shadow.
        Initially I though charging, after service also the same
        • brianho80
          • Sep 2009
          • 198
          What is the guide sheet mod?
          • RRodgers
            • Jun 2009
            • 1947
            Clean the print head with some rubbing alcohol.
            • B0265
              • Jan 2007
              • 718
              This is the guide sheet mod:
              • brianho80
                • Sep 2009
                • 198
                [ATTACH=CONFIG]23651[/ATTACH]
                This guide sheet mod is improve print quality ??
                • Synaux
                  • Mar 2012
                  • 1224
                  No...posting that was just for the heck of it...its not like I was trying to be helpful or anything...
                  Anyway, did you check to see if it is installed? If not, install one (they are cheap...and do enhance CQ).
                  You can also try boosting the Secondary & Primary Transfer Adjustments and maybe a new transfer roller.
