C284 Firmware USB Drive
  • copier tech
    • 8169
    [Misc] C284 Firmware USB Drive
    I've noticed the new C284/e FW has many files, not like the C280 etc that just has the one .TAR file.My question is what files exactly do I need to move or extract to the root directory of my USB flash drive? The manual isn't clear on this!?Many thanks.
  • jotunn
    • 618
    Re: C284 Firmware USB Drive
    You need to copy all the files from directory A5C10Y0-*-*-*-* to the root of USB drive.
    • copier tech
      • 8169
      So just these 3 files for example? (the is the C280e)
      • jotunn
        • 618
        Nope, open folder A5C10Y0-F000-GD1-A9(00) then copy everything from there to the USB drive (many files and folders).
        • copier tech
          • 8169
          OK thanks, so more like this!? there is also a folder within that folder called "cw" is this the old card work folder" do i need to move those contents to the root directory of the USB too????
          I thought the older models were much easier to understand.
          • solidzdawg
            • 71
            Exactly like that,
            youre making it too complicated.
            simply drag all of those files and folders (theres several and several like the above screenshot) onto the Root..the root is the main space of the flash drive the very beginning folder the root folder hehehehe pun intended
            • ni311
              • May 2008
              • 658
              More like that, yes. Just extract all the files and folders in the root directory of your usb stick. Just be sure that your stick is 2 Gb or less; I tried with a 4 Gb Verbatim and the memory was not recognized.
              LE: we posted both in the same time
              Konica Minolta Error Codes - Explanations and Solutions
              • Synaux
                • Mar 2012
                • 1224
                Also, make sure to format the drive to get rid of any preinstalled software (i.e., U3 software) that can cause issues--fat32 is the preference, I believe.
                • Gino_21665
                  • Feb 2014
                  • 15
                  I carried out the upgrade, blue light of start is illuminated do i just switch off and then on or is it supposed to Auto reboot ...?
                  • avecosat
                    • Jun 2012
                    • 305
                    I use a 8Gb transcend memory and its ok , the problem is the USB , I have one with a 2 Gb and not recognized .
                    P.D : dont forget to look the the type and the machine .
                    • ni311
                      • May 2008
                      • 658
                      It is not auto-rebooting; you have to manually switch off and on.
