Fs-527 with pk-517 j72-43
  • -ph-
    • Jun 2009
    • 30
    [Jamming] Fs-527 with pk-517 j72-43
    Hi,
    I'm having trouble with paperjams in the punch unit.
    the paper stops in the punch unit for an unknown reason.
    i checked all the connectors and switched the sensors
    i oiled the punch unit, checked the settings in service mode ( pk517 - 2 holes)
    i really have no idea why the paper just stops during operation.
    any ideas?
    greets
  • tech51
    • 846
    Re: Fs-527 with pk-517 j72-43
    Originally posted by -ph-
    Hi,
    any ideas?
    greets
    I had one do this last year and despite changing sensors, lubing it as you have, in the end we had to replace it with a new one. We never got to find out where the problem was
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • -ph-
        • Jun 2009
        • 30
        Not quite an answer i was hoping for but thanks for your reply.
        • occus
          • 337
          Long time ago...
          I remember that you have to made something with the sensors by setting up the machine, without you get the error and paper jams... something to execute, but i can't find them...
          • kingarthur
            • 1366
            I've had this happen twice, both times I had to replace the FNS pcb
            • Ray G.
              • Sep 2008
              • 22
              [QUOTE=-ph-;400764]Hi,
              any ideas?
              Try re-installing the PK-517 via the operator panel. That has worked for me a few times. Good luck.
              • -ph-
                • Jun 2009
                • 30
                [QUOTE=Ray G.;404979]
                Hi,
                you mean unselect and select the PK-type in service mode and restart?
