C552 oil can P-21 & colours not right
  • copier tech
    • 8200
    [Error Code] C552 oil can P-21 & colours not right
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: C552 oil can P-21 & colours not right
    after the machine attempts to stabilize and fails stop the machine immediately when the oil can appears and remove the belt. If the stabilization patterns are still on the belt after the cleaning unit and the belt is KNOWN GOOD OR NEW, replace HV-2.
    If you even slightly suspect the belt, replace it first to see if it goes away, more often than not its the belt and not HV-2.
    • methogod
      • Dec 2008
      • 922
      just had this happen to a C650...
      Firmware up to latest version (based firmware)
      make sure belt is good, or replace....
      initialize...
      skew adjustment
      run auto registration, if you have not got the code then it was the skew adjust that fixed it...
      press the start button (not sure if you have to from expert mode but in service you do).
      see if it goes away....
      we had first p-21 and then p-22 odd right, well the skew adjust will usually fix the the p-22.
      • copier tech
        • 8200
        Just an update on this, I fitted a new transfer belt & the machine is now running fine, perfect CQ & no oil can icon!
        Many thanks
