Got a P-14 error so I swapped the transfer and cleaned the IDC sensors. I also cleaned the paper dust collector and the transfer roller as well as the PH.
Rebooted the machine with a mysterious paper jam:
So I cleaned and inspected the entire back/side end of the machine (conveyance/duplex/trays b/1-4 paper paths).
There are no jam codes nor anything amiss in service mode.
Changed the transfer belt back to the original.
Flashed the FW because I ran out of ideas (and I had it with me) while I bought a six pack.
It makes several quick clicks that sound abnormal from the fuser "area" (not the typical gear grinding jam that you are used to on these models). Swapped fuser, no luck
I also tried bypassing the door sensor for the conveyance section and booted it with the side hatch open with the same error--this should give a c3102 error.
Perhaps there is something that I am not understanding regarding the startup procedure for these models...or I guess a bad board (that I didn't go near)?
Out of ideas--I think I covered everything--Oh Wait--I cannot print/copy.
**I took a video to demonstrate the jam-noise and will post it if I can get my phone to cooperate.**
