Biz 25 Lamp Error
  • Grunt1775
    • Feb 2013
    • 12
    [Misc] Biz 25 Lamp Error
    There is an Image using ADF, No image when using original on glass. Have already replaced CCD, lamp assy, Overall control pwb, scanner pwb, and updated firmware.
  • mo0651
    • 1054
    Re: Biz 25 Lamp Error
    Does the scanner actually move and lite up, when you scan from glass?
      • 23010
      I didn't see ribbon cable on your list. =^..^=
      • Grunt1775
        • Feb 2013
        • 12
        The scanner will move normally and lite up for the scan.
        • Grunt1775
          • Feb 2013
          • 12
          No, I did not replace the ribbon cable....will give it a try.
