C360 Bluetooth: Mobile/PDA not in system user box
  • Motormount
    • Sep 2010
    • 78
    We have picked up a C360 with the EK-605 installed. I have triple-checked service mode and admin mode settings, even disabled and re-enabled Bluetooth, but Mobile/PDA does not appear in the System User Box. I searched the service manual and the user manuals for everything on Bluetooth and EK-605, as well as the KM knowledgebase, but no hints for this issue.
    It appears the hard drive was formatted before we picked up this unit, but I don't think the Overwrite All Date was done, as there was still network information intact.
    Any ideas?
    Thanks.
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Re: C360 Bluetooth: Mobile/PDA not in system user box
    Any ideas?
    Thanks.
    I believe there is a device driver you have to load in service mode to enable the function. If the HDD was formatted the driver would be wiped out.
    • emujo
      • Jun 2009
      • 3009
      There is no device driver for this...service mode/system2 to enable the Bluetooth settings. I would 1st check to verify you don't have anything turned on under billing settings, then ensure that what is installed is really a 605, not just the additional USB port. Emujo
      • emujo
        • Jun 2009
        • 3009
        pdamobilebluetoothsettings.pdfpdamobilebluetoothsettings.pdfHope this helps. Emujo
        Not sure why it posted twice, but they are the same doc...
        • Motormount
          • Sep 2010
          • 78
          Yeah, I'm thinking it's an EK-604 and the installing tech was just hopeful when enabling Bluetooth. Since I have not actually seen the EK-605 or EK-604, and am unable to locate a picture or schematic, can anyone provide a description or distinguishing marks/labels?
          Thanks again.
          • 907tec
            • 434
            IIRC, the 604 has two open USB ports while on the 605 one of the ports is used by a tiny USB Bluetooth adapter.
            • B0265
              • Jan 2007
              • 718
              The EK-605 have the chip in the picture mounted.
              • Motormount
                • Sep 2010
                • 78
                Thanks for the image, B0265, that clears it up. It's a 604.
                Thanks again.
