Offsetting when using heavy stock bizhub 751
  • rocky_biskit
    • Jun 2009
    • 76
    Customer claims that they selected thick paper when printing, yet the image is not fully fusing. Is there a setting to increase the temp in the fuser to correct this? I have the manual, but I am not sure of which dipsw to use as there seems to be multiple sw's for fuser temp. I was also thinking that advancing the web more often may solve this problem, but I am not able to find a setting for this at all.
    Thanks!
    • 23010
    Re: Offsetting when using heavy stock bizhub 751
    How heavy? Is it within machine specs? Is the heavy stock being loaded to the bypass tray, using the appropriate media type settings on the machine and in the print driver?
    It's on pg 38 of your Field Service Manual. =^..^=
