Bizhub 751 says now printing, won't copy
  • nathicana
    • Aug 2008
    • 335
    This Bizhub 751 used to be connected to an Equitrac copy management device. I followed the procedure to unset the "insert key" message so that the machine could run without the Equitrac. The machine comes up and says "ready to copy" but I am able to run the machine in list output mode only. When trying to make a regular copy the machine scans the original and just sits there saying "now printing" and nothing happens. I can cancel the job and it goes back to saying "ready to copy".
    We have another 751 that has the identical problem.
  • emujo
    • Jun 2009
    • 3009
    Re: Bizhub 751 says now printing, won't copy
    Not 100% sure, but assuming you properly "unset" the device in service mode, didn't the interface connector have a "loop back" plug? If so, you may have to find it and put it back on the connector. Emujo
    • nathicana
      • Aug 2008
      • 335
      I was not present when the Equitrac was installed so I don't know about a loop back plug that may have been removed. The procedure I used in service mode was:
      utility/meter count/details/stop 00/stop 01/stop 9/management function/unset
      • nathicana
        • Aug 2008
        • 335
        Thank you emujo. I found a junk machine and sure enough there was a loop plug on the interface connector. One of the machines is now working properly. I just have to find another such plug or short the wires myself to get the other machine going.
        • fredi adinata
          • Jan 2019
          • 7
          So.What is the solution.I have same problem too.Please Help
          • allan
            RTFM!!
            • 5462
            Seems like the solution was found here.
            Did you try any of the stuff mentioned?
            Whatever
            • copyman
              Owner / Technician
              • Sep 2005
              • 4718
              You can just jump the wires together if you don't have the jumper connector.
              • nathicana
                • Aug 2008
                • 335
                Here is a photo of the shorting plug installed. If you can't come up with the original plug make sure you jump the correct wires.
                As I recall this is in the machine rear upper area. It would be where the management device was connected.
                Remember you will need to unset the management device. I previously posted the sequence that worked for me.
                Good luck
