Bizhub 423 "failed to start" message
  • jwrycza
    Office Systems Expert
    • Sep 2013
    • 90
    I havea Biz423 which displays a "failed to start. Please turn power off/on" message. It will not allow you to do anything unless you restart it and then it comes back up after a couple minutes. It is either a hard drive issue or fax board. In service mode, it has a code B-0003. If I unset the fax board it will print. I just want to make sure it is a fax board issue and not memory of some other type. Anyone have any other ideas or had this problem?
    Thanks for any help!
    • 23009
    Re: Bizhub 423 "failed to start" message
    Do you mean CB003? Fax Board Initialization error NG? (You typed too many zeros).
    Yes, fax board. =^..^=
    • deepdiver
      • Dec 2013
      • 13
      I too have a machine with this problem BH283. New Fax board did not fix it. I am going back tomorrow hopefully with MFP board to fix. It could also be the HDD if Fitted. Mine does not have an HDD.
      • Tonerjockey.com
        • Jun 2010
        • 41
        PROBABLE CAUSES:
        1. Possible FK-508 Fax Kit failure or the Fax Kit is not installed and the MFP is incorrectly configured.
        Verify the presence of a Fax Kit. Ensure that, if there is no Fax Kit installed, the machine settings are correctly configured.
        Service Mode,System 2, Option Board, Status, Fax (Circuit 1 or 2)Unset.
        If an installed Fax Kit has failed, please replace it as necessary (Item #A22M011). Reboot machine.
        2. The machine is equipped with a Fax Kit and an Hard Disk Drive (HDD). The HDD is not enabled or properly formatted.
        Enable the HDD (HD-516):
        a. Enter the Service Mode and select System 2.
        b. Select HDD and select "Installed".
        c. Once the hard drive is enabled, access State Confirmation and select "Memory/HDD Adj."
        d. Next, select HDD Format and perform the Logical Format.
        e. Reboot the machine.
        3. Bad connection between the FK-508 Fax Kit and the Overall Control Board (OACB).
        Reseat the USB cable between the fax option and the OACB.
        • Downunder
          • Aug 2007
          • 174
          This error message has usually come up when upgrading the firmware, on a past occasions I have had to take it down a firmware level and on the majority of cases, Three so far I have changed USB sticks and re-flashed the firmware. Fax boards on all cases never fixed the error.
          • jwrycza
            • Sep 2013
            • 90
            Thanks for all the advise. I replaced the fax board and that took care of the problem. All is happy in the repair world again! Thanks again!
            • deepdiver
              • Dec 2013
              • 13
              Mine turned out to be the OACB
              • jwrycza
                • Sep 2013
                • 90
                Well, after replacing the Fax board, it worked for 3 days before the issue returned. I ended up replacing the hard drive and that took care of the issue.
                Thanks everyone!
