Develop +452
  • CrapAimer
    • 296
    Develop +452
    Hi All
    I ordered a Minolta Cyan drum for a +452 for which I was told if I changed the chip it would work, it didn't came up with a c2255 code which is a drive fault, but the original drum works fine has anyone else had this issue, before I go to the bother of sending it back. ??????
  • CrapAimer
    • 296
    Re: Develop +452
    just to let you all know got it fixed. it was the unit the dev mech was stiff. turned it a few times with a pair os points and it worked away great.
      • 23006
      Re: Develop +452
      Good to know. Thanks for the resolution on this one. =^..^=
