C-203 (License management error occured) on display screen
  • Buddy with ACR
    • Sep 2011
    • 13
    [Electrical] C-203 (License management error occured) on display screen
    You can select OK and the machine will copy, but you can't print. When you select Utililty /Counter key, the first choice selection is missing on the screen. It won't let me set-up printer settings. I tried Data and System Error clear initialization, no help. Can someone help me? Thank you Buddy
  • habik
    • 2013
    Re: C-203 (License management error occured) on display screen
    NV RAM and Konica Support. Good Luck!
    Firmwares HERE
    • Buddy with ACR
      • Sep 2011
      • 13
      What does that mean
        • 23008
        Just out of curiosity, which board did you try to swap, that caused the licensing error? =^..^=
          • 14761
          I have had this problem twice, and both times replacing the EEprom, not the NVRam, solved it.
          Hope this helps
          • Buddy with ACR
            • Sep 2011
            • 13
            The MFP board
            • Buddy with ACR
              • Sep 2011
              • 13
              Hope this helps
              Where and what exactly is the EEprom Thanks
                • 23008
                You'll need participation by the manufacturer to clear the licensing error. There is a clearly defined procedure in the service manual. Start by reading the manual. Then if you are not a Konica Minolta dealer, you should probably involve one to help you clear the licensing error message. The dealer has a website in which they enter encryption codes, then the manufacturer issues a new code to recover your machine.
                Parts alone won't help you. You'll need the help of a dealer.
                My best advice is to hire out this call to a KM dealer. You'll get nowhere by yourself. =^..^=
                  • 14761
                  I give advice based on my experience with certain issues. I won't say replacing the EEprom will solve Buddy's problem, but, it did solve the two licensing errors I have had. (two different machines).
                  Buddy;
                  blackcat is right. Read the manual. If you don't know what, or where the EEprom is, it will help you.
                  If you don't have a manual then I'm sure Paul at "justsmanuals" will be able to sell you one.
