Bizhub 25E constant adf jam at power on/new install
  • axdexter
    • Aug 2025
    [Jamming] Bizhub 25E constant adf jam at power on/new install
    Hello. I am am having trouble with a Bizhub 25E, that has a adf jam that wont clear. I check both ds2, and ds3 and neither one of
    them change states. The are both reflective optical sensors, check connections and re-seated everything. All others sensors check out fine.
    If I unplug the feeder it power ups normally. It got un-boxed with this problem. Has anyone had any problems with this rebadged muratec?
    Thanks for any help
    • 23009
    Re: Bizhub 25E constant adf jam at power on/new install
    I think I'd pin-out the cable from the machine to the DF. At least make sure that you're getting all your voltages. =^..^=
    • wseyller
      • Sep 2012
      • 1129
      Some of these sensors you can look at them thru a smart phone camera viewer and you will see a light shine from them if they are powered on.
      Sent from my DROID BIONIC using Tapatalk
