Bizhub C451 Won't Power Up
  • integritybob
    • 67
    [Dead] Bizhub C451 Won't Power Up
    Copier was working until the operator attempted to replace the waste toner container. The "Replace Waste Toner . . ." indicator would not clear so they tried turning the main power off & on. Now the unit will not power up at all.
    When the main power is turned on (with sub-power on), the orange and blue lights on the left front of the scan section illuminate, and a relay click and a fan can be heard. The main power light on the control panel lights. That's it. The touchscreen does not light up at all, and none of the usual initialization noises are heard. A beep is heard when the sub-power switch is turned off and on, but the lights on the scan section stay on even with the sub-power off.
    I checked voltages on the DC power supply, which seem okay, and removed & reconnected connectors on the power supply and PRCB. Line voltage is a 30 amp dedicated line.
    Before I start replacing boards and power supplies, I was wondering if anyone had seen anything like this on this series.
  • imihm
    • Feb 2014
    • 77
    Re: Bizhub C451 Won't Power Up
    Hello if there is any options installed ,disconnect all and power the machine on
    • integritybob
      • 67
      Thanks for the response. I did try it with the finisher and doc feeder disconnected - no change.
      • Blizzoo
        • Aug 2013
        • 608
        Sounds like a NVRam failure.
        Try an NVRam Restore first.
        • emujo
          • Jun 2009
          • 3009
          I would start with the memory stick 1st. If no success, then the MFP board, then the PCRB. Can you get the MFP to power up in firmware update mode? Emujo
          • elamurugu
            • Mar 2014
            • 27
            Chek the FLASH ROM
            • integritybob
              • 67
              Solved
              It was a bad memory stick. Thanks for all the responses, especially emujo, who nailed it.
              • RookieTech
                • Jun 2008
                • 46
                Re: Solved
                I am having the same issue. I will be pulling the machine from the customer's site tomorrow. Did you reformat the memory stick or replaced with a new one?
                Thank you for your help.
                • integritybob
                  • 67
                  Re: Solved
                  I replaced it. Actually, I replaced both of them, so I'm not even certain which one is the bad one. It has been working fine since then, so I'm okay with that.
                  • RookieTech
                    • Jun 2008
                    • 46
                    Re: Solved
                    Where are the "memory sticks" located? I only see memory modules on service manual part no V865-3000. Thanks again.
                    • integritybob
                      • 67
                      Re: Solved
                      Memory modules, memory sticks, that's them. Appears to be standard PC-3200 512mb laptop memory, although I used pulls from another machine. They're located on the MFP board near the top.
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        you can generally tell which ones dead by the symptoms.
                        bank 0 - machine will do nothing at all, black screen, LED's are on on scanner thats about it.
                        bank 1 - machine will boot but will lock up rock solid at any point upto and including the ready screen.
                        • integritybob
                          • 67
                          Good info, thanks. From that it would appear that bank 0 was defective on the unit I was servicing.
                          • RookieTech
                            • Jun 2008
                            • 46
                            Re: Solved
                            Got it. I will give it a shot and provide an update when available. I sincerely appreciate the help.
                            We were an NEC dealer which brands these Minolta units, but NEC went under and away went our call center tech support.
                            Anyhow, thanks again.
                            • RookieTech
                              • Jun 2008
                              • 46
                              Alright guys removed memory placed existing memory back on boards and the machine came on to Ready screen. However the control panel is unresponsive.
                              It will not take any commands and start button is red. Zero error codes are present.
