Image Transfer Belt Unit C350
  • JPT
    • 13
    I have seen that it is not too difficult to change the transfer belt unit. Does anyone have a tech manual as to how to do this? Or any suggestions and/or cautions on changing out the unit?
  • Bizhub
    • 147
    Give the customers a bag of fuses and you will save loads.
    • JPT
      • 13
      Can you explain what you mean by the fuses?
      • laserman06
        Conservative in Exile
        • Dec 2007
        • 323
        The fuse that Bizhub is talking about is a 80ma fuse. If you pull the transfer belt out about a foot, you will see a silver screw on the top front of the cleaner assy. Take that fuse out and put another fuse in. Reinstall the transfer belt and it will reset and go for a lot longer. That will save a bundle.
        The family that prays together, stays together!
        Smile God created you and He doesn't make mistakes!
        Relax, God IS in control!
        Be still and know that I am God
        Ps 46:10
        • dorusurf
          Image trasfer belt reset
          Hello
          I have a question.
          On wich silver screw we talk about it?
          I have a similar problem with image trasfer belt ( in tech rep mode i can't reset te counter for trasfer belt and fuser maybe because the counter is much over the limit).
          I tried to find that screw but i can't find it.
          Please be more specific.
          Thank's
          • JPT
            • 13
            Laserman, this looks like the same doc that you posted ealier - I don't see the screw that you are referring to...or I perhaps I am not understanding which screw it is. Thanks in advance for your help.
            • laserman06
              • Dec 2007
              • 323
              Open up the document that I posted today. The screw that I am talking about is shown on the first page. It has a red circle around it. The file name is the same however I modified it. Hope this helps!
              Ps 46:10
              • JPT
                • 13
                You wouldn't think that it would be all that hard to find this fuse...I have tried nationally known hardware and electronics stores with no luck. I ended up ordering it on-line only to be told that it is back ordered until the last week in July. Any suggestions??
                • laserman06
                  • Dec 2007
                  • 323
                  JPT,
                  Here is the place where we get ours. You might try them.
                  For anyone who wants to know a good place to get the fuses that will work on the various models to reset fusers and TBU , go to US - Electronic Components Distributor | Newark.com and search for item #48K9877 or S500-80MA-R. Sense we are a large company we got them for 79 cents.
                  Ps 46:10
                  • JPT
                    • 13
                    Thanks a bunch! You have been quite helpful with this issue.
                    I ordered the fuses from Newark (which by the way were less expensive then where I had originally ordered the fuses from).
                    • jodiego7
                      Transfer belt on Konica 8050
                      I would like to know if the transfer belt on the 8050 can be cleaned and polished up like other belts out there. Or is it necessary to place when it has marks on it?
                      • jodiego7
                        need transfer belt info
                        I have a konica 8050 that needs transfer belt work. Does this or can it be polished instead of replaced?
                        • laserman06
                          • Dec 2007
                          • 323
                          If the belt has toner build up on it, you can clean it. I use alcohol and a soft cloth. Let the belt dry completely, before installing. Make sure to put setting powder on the belt, and run clean blade procedure. After doing that run belt refresh and all adjustments.
                          Ps 46:10
                          • mrfixit
                            Senior Technician
                            • Sep 2007
                            • 83
                            Hey Laserman
                            do you know the part # for the fuser fuse for the c350 from Newark?
                            • laserman06
                              • Dec 2007
                              • 323
                              Same as the one for the transfer belt. It is listed above. I have a link in the post where we get them.
                              Ps 46:10
