Bizhub Press C1060 Trail edge poor transfer on second side.
  • Itsthepaper
    Supervisor
    • Dec 2007
    • 91
    12pt gloss about 270gsm, only on second side trail edge transfer is poor. Some sheets come out good but most have the issue, anybody run into this?
    Love the Job Love the Work.
  • marlon29
    • May 2011
    • 51
    Re: Bizhub Press C1060 Trail edge poor transfer on second side.
    hi all,
    try adjusting the duty cycle on the software switch
    • RRodgers
      • Jun 2009
      • 1947
      Check firmware, i think they just released one to fiz this issue.
      • prasad
        • Aug 2009
        • 12
        Try this settings:
        1. Lead Edge Erase = 0.
        2. CPM = Down
        3. Thick BK Mode = On
        4. Fusing Air = Max 7
        5. Hard Paper = On
          • 23009
          Is it flip? Heavy glossy media like 270gsm will sometimes curl on the first pass through the fuser. On the second pass the curled trailing edge pulls away from the transfer belt before the image is fully transferred. =^..^=
          • remati
            • 149
            you have to adjust the transfer in operator mode
            goto the "process adjust" at the tray you have that issue and look to the menu ...go to tranfer adjust TRAIL edge
            • andyf424
              • Jun 2013
              • 126
              what Remati said..... All my 1060/1070's have had to have this adjustment.
              • beetle73
                • Dec 2010
                • 44
                Hi
                Has anyone successfully resolved this issue?
                Thx
