Bizhub 223 hdd option
  • mrfuser
    • 1601
    Have a client asking me to install the hdd option , hd516 I believe, on a 223. Any info on procedure?
    Thanks!
  • igorp86
    • 16
    Re: Bizhub 223 hdd option
    Install hdd on machine, you get install guide how to do it, after hdd format... you will have to intall movie file and that is it.
    • rrrohan
      • Sep 2011
      • 1977
      Originally posted by JustManuals.com
      This Parts & Service Manual can now be purchased for $14.77 and downloaded immediately from:
      Paul@justmanuals.com
      don't buy HDD from km just get it from computer shop, way cheaper
      Then just enable it in service mode, format and do the install data
      • ck1
        • 485
        May i know the data file same as C220 model (A0ED0Y0-A000-G00-00_Movie.exe ) ? if not can send me ? thanks
        • mrfuser
          • 1601
          Way way to hijack a post
          • ck1
            • 485
            Never mind just lazy to download ...
            • emujo
              • Jun 2009
              • 3009
              You can use an off the shelf HDD, but you may have trouble with the connectors that come with the kit, you need a SATA and a power connector. Also there is a step that has you x-fer the data from the SSD board to the HDD as the SSD board (not to be confused with the "e" series SSD board) is no longer used. Emujo
              • rrrohan
                • Sep 2011
                • 1977
                oh good point about the power cable
                • emujo
                  • Jun 2009
                  • 3009
                  Yeah, off the shelf is fine for replacement HDD, but you gotta have the connectors...Emujo
                  • mrfuser
                    • 1601
                    Can't get movie file installed. Hdd works fine but when I go to install movie file it won't show the SET button when I choose movie file. Any ideas?
                    • mrfuser
                      • 1601
                      Renamed file and it worked fine!
