C451 jamming
  • mrfuser
    • 1626
    C451 jamming
    C451 jAms coming out of fuser. Seems like the two white drive gears need replaced just past fuser before exit
    Anyone know those part numbers?
  • 907tec
    • 434
    Re: C451 jamming
    Gear 16T (1) - A00J 8946 00
    Gear 16T (2) - A00J 8953 00
    or the complete assembly:
    Eject Drive Unit - A00J R726 00
    • rrrohan
      • Sep 2011
      • 1977
      Re: C451 jamming
      id also check the fuser drive gears and make sure there is no play in the shaft.
      ive seen a few with the bearing that holds the shaft in position worn out allowing the shaft to move
      not that its related to you problem but probably worth doing at same time as Exit Dr Unit if it does look worn
      • malthus
        • 29
        Re: C451 jamming
        exit drive bushing wears out causing poor meshing to drive to exit ,you can temporarly make a repair by turning the bushing through 180degrees but as this quite a long job it is better to replace the bushing when stripped down ,
