Bizhub C224e Deformed colors-registration
  • DadO
    • Dec 2007
    • 403
    [CQ] Bizhub C224e Deformed colors-registration
    I have 2 machines confirmed doing this very strange problem from start of installation. One have 25 k and other 54k copes. It's getting worst and more often. Machines are installed roughly 10 months ago.
    This issue it's not constant and it will appear randomly. Reports i got is that is happen most on larger paper sizes A3,SRA3. It happens when machine is printing lets say 100 pages. This problem will appear from page 50 to page 70 but it can happen from page 1 to page 100. It's totaly random. But most it happens when user replenishes paper in the middle of print yob, again randomly.
    Link to sample. Page one - problem, Page 2 ( page 1 should look like page 2 )
    I tried on bout machines:
    All firmwares from g20.42 to g20.C8
    Tried SSD fix firmware ( i know it's not related but what the heck )
    Tried to format drive and start from g20.41 but didn't test machine yet
    Thank you ALL for any kind of answer!
  • DadO
    • Dec 2007
    • 403
    Re: Bizhub C224e Deformed colors-registration
    Had a bad link for sharing. Now its fixed. (if only copiers would be this easy )
    • SmellsHot
      Head Tech
      • 512
      What program is this being printed from? Try to save as a PDF and try the print job.
      Which driver are you using? PCL, PS?
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • minimerlin
        • 851
        Looka like the sort of output you get with a duff MFP Board.
        Please do not PM me without asking first.
          • 14810
          I have had a failing printhead cause problems like this. Check for printhead codes in service mode.
          Hope this helps
          • Blizzoo
            • Aug 2013
            • 608
            Take a shot at Printer Control Board
            • Synaux
              • Mar 2012
              • 1224
              Maybe PH board?
              • JR2ALTA
                • Feb 2010
                • 2033
                run a stabilzation first before parts/boards
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  • DadO
                    • Dec 2007
                    • 403
                    Here is another sample from another machine:
                    One machine is using PS and another PCL, at least 90% of time.
                    I updated drivers whit newer version but didn't help in both cases.
                    Mainly Corel draw x5-x6 ver. and PS and ilustrator. Will ask costumers if they remember what program was from this 3 when problem appeared.
                    Will check for lasers codes and report back in monday
                    Thank u all for assistance ( and thx for this forum! )
                    • AjitN
                      • Mar 2009
                      • 287
                      I faced similar problem in C360, wherein there was flat cable at PH control board was defective.
                      Hope this helps.
                      • tec
                        • Jun 2012
                        • 7
                        Hi,
                        Any resolution to this problem? I have something similar on a +284.......
                        • AjitN
                          • Mar 2009
                          • 287
                          Hi
                          found any solution, just want to know
                          regards
                          • Hansoon
                            • Sep 2007
                            • 3389
                            *removed*
                            Sorry.
                            Hans
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              E4 firmware is the latest and has mentioned in the list of fixes colour registration drift. Sorry, cannot look at samples at present, but i know c8 firmware is old.
