Blank Copies/ prints
  • rhansson
    • Apr 2014
    • 13
    [Misc] Blank Copies/ prints
    Konica Minolta C364.
    Have P codes of 5,6,7,8,9,21 & 28. Have cleaned relevant sensors. Replaced Print Head assembly, still faulty. Replaced MFP Board, Still faulty. Replaced PRCB, Still faulty also replaced print head relay board, still faulty.
    Have latest firmware installed. have checked ribbon cables and look o.k.
  • copier tech
    • 8107
    Re: Blank Copies/ prints
    Have you replaced any of the image units?
    • SmellsHot
      Head Tech
      • 512
      Is there any image on the belt or IU's? Have you checked operation of the solenoid for the IDC? That's what will generate these P codes during stabilization
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • rhansson
        • Apr 2014
        • 13
        No image is on the belt or image units, black or colour. will check solenoid operation though. Attempted to check SD2 through load check, but alas it is not listed unlike SD1 and SD3.
        although would suspect that solenoid not at fault as no image on transfer belt.
        • rhansson
          • Apr 2014
          • 13
          Have not replaced any of the image units yet as i am not getting any image on the image units or transfer belt
          • rhansson
            • Apr 2014
            • 13
            Fixed Fault by replacing the High Voltage unit, Part no: A161M40601. After shining a light on the drum And getting no image any where, this suggested to me that the drum was not getting any charge so that is why High voltage board was replaced.
