fuser error code C252
  • jtd55
    • Dec 2013
    • 30
    Hi Guys
    Have got a call from my head office to call and have a look at a fuser error code c3451 problem on a konica c252
    am picking up a replacement fuser unit on my way to the job is there a sequence to reset fuser error codes
    on these machines i dont work on them (I do Ricoh kit) and am having to cover for there engineer who's away
    on a holiday.
    Regards
    jtd55
  • copier tech
    • 8174
    Re: fuser error code C252
    From service mode select system 1, initialisation then system error clear, press start, then power m/c off/on
    • Solution
      • 10
      Hello there!
      Hold the Utility/counter buttom when booting the machine for a few seconds - then a error reset should be diplayed on the panel!
      • rrrohan
        • Sep 2011
        • 1977
        Trouble reset. Its a common fault that they allow the new machines to auto trouble rank b and c codes.
        I'd be tempted to get customer to try that before you waste a trip
        • jtd55
          • Dec 2013
          • 30
          Thanks guys for your help replaced fuser old one was shot paper wrapped round rollers reset code worked .
          Regards
          jtd55
