shade(skew) in scaning to smb on c652
  • juve
    • Dec 2012
    • 86
    [Misc] shade(skew) in scaning to smb on c652
    hello,
    I have encountered a problem that maybe someone can help me.I went on a c652 that when scaning for example to smb the result scan is coming out with with a scew and a shade at the top left margin(as you see it).but when make copies normally from radf this misallignment is not seen.attachment of the scan is here under.can somebody gives me a tip.
  • Blizzoo
    • Aug 2013
    • 610
    Re: shade(skew) in scaning to smb on c652
    I had once that on a different Bizhub,I made again the DADF adjustments and after was fine.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Also there was a firmware update that helped. It did not eliminate it but did help.
      • juve
        • Dec 2012
        • 86
        you did again the DADF?and whats this?can you explain?maybe the radf initial settings?
        • Blizzoo
          • Aug 2013
          • 610
          Yes,the RADF,like in the instalation manual,adjust skew feed etc...
          Sorry for DADF thing,i work on many other brands and document feeders are named different.
