konica 7055 don't recognized finisher FS 106
  • LeonTsi
    • May 2025
    [Dead] konica 7055 don't recognized finisher FS 106
    Hi all, i have a bloblem with my copier machine. I tried to clear a switch of finisher FS 106 so i took a conector when my copier machine konica 7055 was on. After that my machine don't recognize the finisher, i know that the problem is form dipswitch settings but i dont know what? can someone help me what must i do? thanks a lot!
  • LeonTsi
    Re: konica 7055 don't recognized finisher FS 106
    noone??????
    • Synaux
      • Mar 2012
      • 1224
      noone??????
      I don't understand....maybe you should try rephasing you issue for us...
      • LeonTsi
        Hi mate, thanks for your replay. What don't u understand? my question is what happened my copier machine don't recognize the finisher...... if you can help me about it tell me to give you many Information about my problem.... thanks a lot!!! i will waiting you....
        • LeonTsi
          Synaux bro, cos i don't really know if you get my message here send to my mail leonpolymer@yahoo.gr to talking...I'll be happy!!!
          • Luther
            • May 2006
            • 682
            Did you touch a dip switch? if not try this, turn machine off and on with finisher NOT connected, then turn it off connect finisher and turn it back on you should be good to go
            • LeonTsi
              Thanks bro, i have trying many times that but don't working..... something else you have your mind.....???
              • LeonTsi
                I have fix my problem, all is ok... thanks!
                • RRodgers
                  • Jun 2009
                  • 1947
                  If you disconnected the finisher while the power was ON you've blown the board. With a 7055 consider it a total loss. Good luck getting a board, you might be able to get it fixed at a board repair shop (Hytech) but ALL of us here would prefer you take that money and invest in a newer machine.
