BizHub 601
  • copyman
    Owner / Technician
    • Sep 2005
    • 4721
    BizHub 601
    Installed new drum and 250K pm kit. I didn't do
    the developer because I had just done that a week
    ago. Quality was good before I did the work. After
    work the copies are washed out. I went back over
    my work 3 times. I have done at least 50 of these
    PM/drums and never seen this. Of course I reset
    drum & other counters like I always do. Then did
    the peculiarity adjustments by the book. I didn't
    do the cartridge set mode because developer was
    done week ago. Not sure if this would have
    anything to do with it?
    Please see attached sample
    Any ideas appreciated.
    TIA
  • emujo
    • Jun 2009
    • 3009
    Re: BizHub 601
    Like the test chart...I would take another look at the coronas (charge and x-fer/sep), the CELs. Emujo
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      Re: BizHub 601
      Check the two black covers on the charge corona unit and make sure they are fully locked down in place or your charge grid won't set right and can cause issues as the drum will rub on it...
      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
      • SmellsHot
        Head Tech
        • 512
        Re: BizHub 601
        Cartridge set should be performed any time you remove the drum unit. It should be the very first adjustment you do. Did you do the grid voltage adjustment? Id do cart set and then Run through all of the auto adjustements. After that. Id do 25 dbl sided #12 test patterns to cycle through toner/developer. The. I'd check your ld1 ld2 lasers to see if they need to be adjusted.
        Everyone has the right to be stupid. Some people just abuse this privelage more than others
        • Downunder
          • Aug 2007
          • 174
          Re: BizHub 601
          Have you tried stopping the copier before the image is transferred onto the paper to see how solid the image is on the drum. Lets you know whether it is charge or transfer problem. Also on the back of the drum there is a voltage stamped on the back plate of drum - anywhere from 700 to 721 usually -- have you set your settings to this (not too important but still part of the process)
          • copyman
            Owner / Technician
            • Sep 2005
            • 4721
            Re: BizHub 601
            Thanks everyone. Turned out to be the T/S corona unit.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              Re: BizHub 601
              When the black film under the plate starts peeling down you get issues like that. And an even more interesting effect when people think its a good idea to just pull out completely
