C451 Fuzzy horizontal lines on whole document
  • stryder
    • Apr 2014
    • 33
    Hi guys, wonder if anyone has ran into this problem before and what you did to solve this problem. This c451 is printing out documents that has rows and columns of 4 thick black fuzzy horizontal lines on the whole page. Any input would be appreciated, updating the firmware, changing drum, developer, belt, fuser did not work.
  • copier tech
    • 8101
    Re: C451 Fuzzy horizontal lines on whole document
    Can you post a sample?
    • stryder
      • Apr 2014
      • 33
      • copier tech
        • 8101
        Interesting, does it do the same in colour?
        • stryder
          • Apr 2014
          • 33
          Yes, every printed document, color, bw, print and copy
          • minimerlin
            • 851
            MFP Board?
            Please do not PM me without asking first.
            • copier tech
              • 8101
              Looks like a PH fault, have you got any P-codes?
              • jotunn
                • 592
                You've got damaged memories on mainboard (PWB-MFP). It could be also damaged SO-DIMM memories, but it's much less possible than PWB-MFP fault.
                • stryder
                  • Apr 2014
                  • 33
                  So possibly a bad MFP, will have to try that then. thanks
                  • mikeena
                    Branch Technical Manager
                    • Mar 2007
                    • 218
