konica c552 resetting color chips
  • acsolutions
    • Jun 2010
    • 519
    [Misc] konica c552 resetting color chips
    Hello, I went to reset all IU on a c552, found the black but when removed the front covers on the color units, no chips to be found! Just wondering if I'm going to need a rechip device, or is there another way to reset the units. Thanks
  • copier tech
    • 8172
    Re: konica c552 resetting color chips
    If they are the original image units (from when machine was new) they don't come with chips, you have to fit a new set of units then you can chip them.
    However you don't need the chips, you can simply disable the "replace IU" message is service mode & run the IU's until they fail.
    Set switch 51 HEX to F0 & switch 55 HEX to 0C
    • emujo
      • Jun 2009
      • 3009
      If you find that the hex values you are trying to input will not stick, you must update the firmware. PPLM mod gave the color series the ability to run all the consumables to failure. No need for a chip re-setter. Emujo
      • acsolutions
        • Jun 2010
        • 519
        can the Fixing unit and transfer unit be reset?
        • copier tech
          • 8172
          With the firmware yes, you can turn off the fixing unit & transfer unit warnings
          • KM7155
            • Aug 2008
            • 146
            Hi, can i hide the IU warning on Bizhub C252 machine?
            • copier tech
              • 8172
              Yes, but you'll need to update the firmware first.
              Then you simply set a couple of soft switches then no more "replace image unit" messages!
              • emujo
                • Jun 2009
                • 3009
                Don't quote me, even though I'm quoting you, but I believe the PPLM mod was for the Bizhub C353 series and up to the C652. After this the MFPs came with the ability to turn off the end of life settings w/o any additional firmware. I think you are stuck with the "2" series. Emujo
                • KM7155
                  • Aug 2008
                  • 146
                  Hi Emujo, are u trying to say that the 2 series machines cannot hide the " replace imaging unit" warning message?
                  • emujo
                    • Jun 2009
                    • 3009
                    There was never any mention of the 2 series when this firmware came out...I believe you can still extend the life with the no stop settings, but the message will still be displayed. Also, even with the PPLM firmware, the oil can will still appear on the control panel when the units are past life, but no message and no failure. Emujo
                    • ewizzy
                      Dirty toner monkey
                      • Feb 2014
                      • 55
                      Why, yes, they can.
                      develop end of life reset.pdf
                      • acsolutions
                        • Jun 2010
                        • 519
                        Originally posted by ewizzy
                        Why, yes, they can.
                        [ATTACH]25182[/ATTACH]
                        thanks for the update!
                        • pappyvonsillypants
                          • Feb 2013
                          • 30
                          To reset the fuser and belt on this model u have to go to counters and it has a tab that states "new release" highlight that and open and shut the front door and hit the start key to reset. it was an addition to be able to test the belt or fuser with out having the counter clear if that is not the issue so you can keep the belt or fuser as "new"
