"The component is open." (pointing at the lower right door) when the door is closed.
    • 23009
    I had a bizarre couple calls the other day. This is the first:
    It's a bizhub 654e. Sounds simple, right? So I leave the tray two feed unit connected, unscrew it, an let it hang to the side. The meter tells me that my supply voltage to the doorswitch is 1.2vdc, and changes state from 0 to 1.07vdc ... what? Isn't that supposed to be 5.0vdc, changing state from 0 to 4.5vdc?
    All the other sensors in the tray #2 feed section read the same ... very odd. Once I get the back cover off, and the power plugged back in, it's back to 5.1vdc, and changing state like it should. It sounds like time to dig out the power quality analyzer.
    We'll have a nice 48 hour sample by Monday, but the 5 minute snapshot says it all: Every time the printer starts up, the ground to neutral spikes to 2.0vac then settles back down to 0.9vac. The machine also locks up in low power mode, and won't wake up without powering off/on.
    What do you suppose are the chances they'll do anything about the power (other than complaining, that is)?
  • Max
    • Oct 2011
    • 560
    Re: "The component is open." (pointing at the lower right door) when the door is clos
    You probably have already done the SSD and main F/W upgrade. Should help with the lock up at least.
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      I believe the SSD update is for 554e and lower.. But FW update should correct the low power lock up, I've had that issue before on that model.
        • 23009
        Once we get some resemblance of acceptable power, then we'll worry about firmware. Do you know the level firmware to load? =^..^=
        • stevena86
          • Oct 2012
          • 130
          G00-E4 is the latest for the 4e series, I'd go with that.
          • Max
            • Oct 2011
            • 560
            Yes you right its up to 554e my bad.
            • Synaux
              • Mar 2012
              • 1224
              Let me guess, they have the lights, the computers, a 554e, and a Large Hadron Collider all on one circuit.
              Hope you get it sorted out
              • Grey
                • 38
                Quick power fix.
                A great tech from years ago, "Mr. Scott", was fatigued from re-calls at a local school.
                He explained that the copier required correct amps and voltage to preform to specs.
                No one really could be troubled by the silly copier tech.
                Until he brought out a special machine cord made for the school.
                The hot and ground wires were twisted together to blow the circuit breaker.
                Using leather gloves to protect his hands, he inserted the cord into the wall outlet.
                A bank of teachers computers went down, along with the water cooler.
                The power issue was corrected the very next day.
                No one at the school knew exactly what had really caused the outage.
                Grey
                • byronf
                  Senior Member
                  • Sep 2017
                  • 109
                  Hi Genlteman,
                  I need assistance with this issue. What was the resolution to this problem?
