Machine has a lot on it, but after fixing so many other issues - seems like this shouldn't be that complicated.
Tried upping the voltage, +1 / -7 thing.
Here are images...
you can see on a 30 page stapled set, where it used to get better, after the first 10 pages, now it doesn't go away.
belt is almost brand new, black IU is not far behind. From what i can tell its toner, not DV building up on the transfer roller.
I am guessing i should try to swap out the Black image unit see if that helps it out...
Here are images...
