Bizhub C284 Service mode
  • MFPTech
    • 486
    Hi,
    This might sound like a stupid question but when I go to Menu - Counter there is no KeyPad tab below or above the Meter Count.
    Any ideas how to call the service mode please?
    Thanks in advance!
  • xscotty1990
    • Nov 2013
    • 40
    Re: Bizhub C284 Service mode
    Hi,
    if you got a c284 just push the Display over to the left side then you will see the keypad
    Greetings
    Marco
    • stevena86
      • Oct 2012
      • 130
      Originally posted by xscotty1990
      Hi,
      Greetings
      Marco
      This or if it is an e series, top left corner there is a soft key labeled 'Display Keypad' and bam there you go.
      • MFPTech
        • 486
        Hi,
        Greetings
        Marco
        Thank you for your help and for saving my the embarrassment!
        However, not sure if I am the stupid one or Konica for coming up with such an inconsistent design.
          • 23009
          When going through the keystrokes to enter service mode, go slowly, like 2 seconds between each keystroke. If you don't hear the beep with each keystroke it won't work. I'm thinking of the e-series. =^..^=
          • stevena86
            • Oct 2012
            • 130
            We turn the sounds off at my work. You can do it without the beep. I just go at a steady pace. Too little or too much time between the keystrokes causes it to not work.
            What was wrong with hard keys anyway?
            • xscotty1990
              • Nov 2013
              • 40
              I have been on training for bizhubc454e for a while.
              They said that the machine recogneizes the touch on the
              touchpad but just doesnt beep. There must be a soundlag or something.
              Just switch off the keypadsound and everything is fine.
              Greets
              Marco
              • rrrohan
                • Sep 2011
                • 1977
                Physical keypad is a option now. Funny how things like duplex and dual scan that use to be optional extra are now standard but keypad that's been around for years as standard is now the option
