Bizhub C203, Cannot open the copier in browser by typing its IP Address.
  • mearmi
    • Oct 2010
    • 350
    [Misc] Bizhub C203, Cannot open the copier in browser by typing its IP Address.
    Hi
    We have C203, Cannot open the copier in browser by typing its IP Address.
    But it is pinging.
    Please advise
    mearmi@hotmail.com
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Bizhub C203, Cannot open the copier in browser by typing its IP Address.
    that engine doesnt really work well with anything other than internet explorer.
    If your using google chrome or safari you will generally just get a blank white page and nothing else.
      • 14891
      These actually only work well with Firefox. IE and Chrome will only load blank pages
      • mearmi
        • Oct 2010
        • 350
        Thanks for your msg. I am aware of that but the problem is in Firefox also it says unable to find data or sometime no connection but it is pinging in command prompt.
        thanks
        • emujo
          • Jun 2009
          • 3009
          1. Unplug the MFP and re-ping to establish a duplicate IP issue.
          2. If the pings are interrupted when disconnected, look in the Admin settings, HTTP settings to verify you have allowed an HTTP connection (can be disabled).
          3. Could be an SSL problem, if you created a certificate and enabled SSL, any HDD problems could have corrupted the certificate. A HDD format, network settings initialize, firmware and movie data reload should bring everything back. I use IE Mozilla, and Chrome and all 3 browsers work with most MFPs later that the C252 series and the B&W 421 series. EMujo
          Since you're in Australia, you might have to type the IP address upside down..LOL
          • gpsorell
            • Aug 2009
            • 7
            Corrupt data on the Hard Drive can also cause this symptom. Try formatting the Hard Drive, the procedure is in the Service Manual.
            • eg101
              • Jan 2005
              • 131
              Since you're in Australia, you might have to type the IP address upside down..LOL[/QUOTE]
              Naah, they're standing upside down anyway.
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                I own one (C253) with the last released fw and it only works with IE. I've never seen it work with anything else. I dont even run firefox and had no problems setting up SSL etc for papercut MF to be installed, using IE on my windows 8.1 machine.
                • kingarthur
                  • 1379
                  I've had this a couple of times....whilst holding down the CTRL key , refresh your browser, it's worked a few times for me
                  • mearmi
                    • Oct 2010
                    • 350
                    Thanks a lot for your help. HDD Format helped me out.
                    All Good. Thanks once again
                    • rrrohan
                      • Sep 2011
                      • 1977
                      Only thing IE is good for is downloading Firefox
                      I think its a cookie or cache issue.
                      I had one where changing from IE to Firefox helped but if I had my laptop connected with cross over cable all of the big 3 browsers worked.
