I'm working on a bh600 that will run one print and then says warming up. I have installed a new drum cleaning blade and toner board on drum unit. The print I get is blank. When I go into charge adj after running a copy or print all the settings are gone, if I power off and on the copier all settings come back. If anyone has any ideas it would be appreciated.
Thank you
Thank you
