DF-621 jamming bizhub 363
  • jujitsu47
    COPIER TECH SPECIALIST
    • Jun 2014
    • 20
    [Jamming] DF-621 jamming bizhub 363
    Jamming alot on 2nd page and others. i have replaced the feed roller and seperation roller assy. Happens most on scanning feed, but does also on regular copy feed originals. adjusted adf registraton feed loop and it did help the regular feed originals but not the scanning. any help is appreciated...
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: DF-621 jamming bizhub 363
    There is a tech bulletin about adjusting the reading motor tension, adding some spacing washers, changing the flag sensor, changing the front and back lever assemblies, and changing the gear assembly. I've been fighting this issue for about a year seeing it mostly with customers with high scanning volume. I've recently did the levers and spacers for a customer and need to check on them to see if it's finally resolved this issue.
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      Replace the front and rear lever assys.. They changed the design of them recently, and we had a couple jamming and we replaced them, and that seemed to do the trick.
      Here's the part numbers for the updated parts: (A143PP9P01 Lever Assy (Front) ) & (A143PP9Q01 Lever Assy (Rear) )
      • jujitsu47
        • Jun 2014
        • 20
        i ordered the levers, will update ya all when arrive and install.....tks
          • 23002
          Jam codes? =^..^=
          • JR2ALTA
            • Feb 2010
            • 2032
            A common jam, (cost-free!), on these models is the angled sensor on the top cover of the adf. It's easy to overlook but is very prone to paper dust, I promise it's a legit fix for registration jams. Just clean it.
            • jujitsu47
              • Jun 2014
              • 20
              Jam codes? =^..^=
              yup, waiting on parts....backordered... i had jam codes, but left on table. good point though....lol
              • Kidaver
                Ghoulscout
                • Apr 2011
                • 912
                yeah seems the levers are in demand lol I ordered some and it took about a week longer for them to come in. The jam codes you normally see are 66-02. Tech bulletin TAUS1200978EN has all the info....it's been revised 4 times so far...
                • Cookr
                  • Dec 2011
                  • 184
                  Can anyone give me a copy of this bulletin TAUS1200978EN I cant seem to find it. Thanks
                  • CompyTech
                    Super Tech
                    • Feb 2011
                    • 706
                    Appears since KMBS has updated their knowledge base, that TAUS1200978EN is no more and has been replaced by this KBA01200978.
                    • allan
                      RTFM!!
                      • 5462
                      Jip...
                      The square hole for the reflective sensor black out gets paper fragments in there.
                      Whatever
                      • Cookr
                        • Dec 2011
                        • 184
                        Hmm when I search for that one under the bulletins I don't see it either?
                        • CraigW
                          • Dec 2010
                          • 417
                          Neither bulletin #s can be found.
                          To me...... the paper present actuator with the added magnet is one of the best resolves for 66-02.
                          Only occurs when utilizing the 70 OPM option during scanning.
                            • 23002
                            Originally posted by allan
                            Jip...
                            I believe that one is 66-05, but we still don't know what code the poster is getting. =^..^=
                            • Cookr
                              • Dec 2011
                              • 184
                              Happen to have the part number for that? Thanks
