konica minolta 253 testpage
  • balendran
    • Feb 2014
    • 9
    i have konica minolta c253 copier. in that machine their is a alliment problem please help me
  • stevena86
    • Oct 2012
    • 130
    Re: konica minolta 253 testpage
    Are the guides in the paper tray set firmly against the paper?
      • 15011
      Are you asking about the skew or the colour shift in cyan and yellow?
      Check the cyan and yellow printhead adjustments
      • rrrohan
        • Sep 2011
        • 1977
        I wouldnt be surprised if the print heads needed replacing. fairly common issue
        this would explain paper skew but not the individual skew of certain colours
        • stevena86
          • Oct 2012
          • 130
          Haha, I didn't even see the color shift. I loaded the image and saw the skew and typed my reply and moved on.
          • mikeena
            Branch Technical Manager
            • Mar 2007
            • 220
            lmao at first i saw the skew as well. but then noticed the color shift. i dont have a 253 near me so i can give you what the book says
            Scanner system: abnormal image
            A. Typical faulty images
            B. Troubleshooting procedure
            Data on
            previous page
            Data on
            current page
            Step Section Check item Result Action
            1
            Cable connecting
            scanner and
            printer
            Connector is connected properly
            with no pins bent.
            NO Reconnect.
            2
            Image processing
            board (IPB)
            Connectors on the image processing
            board are connected properly.
            NO Reconnect.
            3
            MFP board
            (MFPB)
            Data on previous page is mixed
            with data on current page.
            NO Reinstall the memory.
            4
            Test Mode
            [Service Mode]
            The problem is eliminated as
            checked with the image on a test
            pattern produced.
            NO Change interface connection
            cable.
            5
            Image processing
            board (IPB)
            The problem is eliminated after the
            interface connection cable has
            been changed.
            NO Change image processing
            board.
            6
            Printer control
            board (PRCB)
            PH relay board
            (REYB/PH)
            Check the connection of connectors,
            harness, and flat cables
            between PRCB and REYB/PH, and
            correct if necessary.
            NO Change printer control board.
            Change PH relay board.
            7
            MFP board
            (MFPB)
            The problem has been eliminated
            through the checks of steps up to 6.
            NO Change MFP board.
            I believe but may be wrong in tech mode there is color regis. check it
            also check these areas as well
            10.4.4 Printer Area.............................................. ................................................. 348
            10.4.5 Scan Area.............................................. .................................................. . 353
            10.4.6 Printer Resist Loop .................................................. ................................. 357
            10.4.7 Color Registration Adjustment .................................................. ................ 358
            10.4.9 LD adjustment........................................ .................................................. . 359
            10.6 Imaging Process Adjustment .................................................. .......................... 362
            10.6.1 Gradation Adjust .................................................. ..................................... 362
            these are all pages in the service manual. if you dont have it let me know i can get it to you
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              ive seen this when the print heads start to fail too. We are ofcourse all assuming the idc sensors are clean and the basics have been checked and that you are a technician.
              of the failures i've experienced with print heads its always been the polygon motors seizing up, or once one mirror exploded into shrapnel and blew an icp on the prcb but thats only ever happend once.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4785
                Before doing anything I would try swapping out the yellow image unit. Like the other poster said if not done already then clean sensors. Then do gradation adj.
