Customer has a Bizhub 423 with a handful of computers that print to it. Every once in a while it will print a page that is almost blank. In one corner of the page it has a little checkerboard pattern few millimeters in size and a plus sign right next to it. It is the same every time. During this time the data light will print. In the job list history it always shows the user as: PRINT and the document name as: PRINTER. Looking thru the history it seemed to happen approx every 5 to 20 minutes. I've seen around 35 minutes as well. All normal printing seems to work just fine.
I was out at this customer last week and I decided to update the firmware as it was very old. I was there for at least an hour after the upgrade to clean the copier and such. These pages did not print out anymore. Then couple days later the same call came back in.
History on this copier. Back on 8/1/13 it shows they had possibly the same issue and tech removed network cable from the surge to resolve it. On 3/19/14 MFP board was replace for c-fc24 code.
I suspect one of the computers on the network is causing this. I though about doing wireshark and filtering only packets to the copiers IP address. Only problem though is it would be nice to be able to analyse all devices on the network at once. I don't have a network hub or any other way to sniff all traffic going to the copier. A hub is hard to find anymore.
Any suggestions how I can isolate this and/or possible reason for this happening.
