Noise from waste toner section c253
  • ck1
    • 485
    [Misc] Noise from waste toner section c253
    Need help ! any have photo how to remove the waste toner collecting mechanism section ? thanks
    no ideal to open.Suspect wate toner stuck at this area . any idea for this issue ?
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    AFAIK going from the c252 which this engine is based on. The waste toner section is in the transfer belt and the box sits below it. I've had a few clog up in the past, couldn't ever really find a solution, just clean it out and replace transfer belt if necessary.
    Sent from my Nexus 7 using Tapatalk
    • chivozx
      • May 2014
      • 34
        • 14811
        Re: Noise from waste toner section c253
        This is an almost complete teardown. Everything off the back. Everything out the front. Side door off. May even need to remove scanner bed. Definitely not a 20 minute job. Take lots of pictures for re-assembly.
        And don't forget to replace the two beveled gears that are grinding.
        Hope this helps.
        • emujo
          • Jun 2009
          • 3009
          Very difficult, requires a teardown to frame to accomplish. If you can remove just enough to access the rear frame section, then you can use a vac, and a long paperclip to break up the rocklike clumps. EMujo
          • stevena86
            • Oct 2012
            • 130
            Just like others have said. It is such an intense repair that we have straight up replaced two of the machines that have done this to us. Mainly because we repaired one, but the damn thing did it again in only a few thousand clicks.
            Good luck to you.
            • ck1
              • 485
              My god.. the problem is hard to take out the section for clean out ... no sure is toner supply section or waste tone section .
              • chivozx
                • May 2014
                • 34
                Antes de desmontar diagnostica de donde procede el ruido.
                Vacia el bote de residuos, aspira la tolva de la banda de transferencia.
                No desesperes, normalmente es una averia facil.
                Before removing diagnosed from which the noise.
                Blank pot waste hopper, aspires transfer belt.
                Do not despair, it is usually an easy breakdown.
                • copier tech
                  • 8172
                  This is a lesson for all only use genuine toner!
                  • emujo
                    • Jun 2009
                    • 3009
                    I disagree, all of our C353s that went through this issue used only KM supplied toner. I believed the issue was due to non use of the color modes, we would see this mainly on MFPs with high B&W counts, but almost nothing on the color side. Emujo
                    • copier tech
                      • 8172
                      Fair enough, but as a precaution it's not worth using compatible toner surely.
                      • emujo
                        • Jun 2009
                        • 3009
                        Now, I agree...aftermarket toner sucks. Emujo
