Bizhub 200 C2557 after dev unit change.
  • wseyller
    • Sep 2012
    • 1129
    Error C2557. I changed the developer unit, developer, and the drum all at once. Counters cleared correctly. F8 I noticed was taking longer than usual and it didn't sound like it was doing much. Got C255C error.
    After trouble reset it always codes right away C2557
    On phone with KMBS rep. We tried different ATDC SET settings no luck. I notice that when running F8 the toner bottle doesn't turn.
    Only errors in service history is the C2557 (about 15 of them) and the C255C.
    KMBS rep recommended PWB-A board.
    Want to see what everyone's thoughts are. I am 100% sure I did the replace of these parts correctly as I have much experience doing these and know how picky they are.
    Some history: The drum I just replaced was at 20% when I arrived. I changed this drum and dev back in Feb when it coded C2557. A year before that I changed dev unit, dev, and drum after it had coded C2557.
    • 14691
    Re: Bizhub 200 C2557 after dev unit change.
    The first place I would start is an ATDC sensor. I know you said you replaced the dev unit, but it could still be bad. Then try the PWB-A.
    I have been working on these machines since they came out and last week was the first time I have experienced an issue doing an F-8. I cleared the counters, checked to make sure they had cleared, ran the F-8 and got a C-2557. I again checked the counters and the drum counter had magically gone back to it's pre-cleared state. I cleared it again, ran F-8 and all was well.
    I know this has nothing to do with your issue, I just thought I would share. lol
    • wseyller
      • Sep 2012
      • 1129
      Yes I always check the counter again before F8. I know the same issues.
      But let me ask. Would a bad sensor cause the bottle to never turn during F8. There are no other error codes listed.
      Sent from my DROID BIONIC using Tapatalk
        • 14691
        As far as I know the bottle shouldn't turn during F-8. Plus, if the sub-hopper is already full, it doesn't need to turn.
        The dev comes with optimum t/c ratio so no toner is adding during an F-8
        • wseyller
          • Sep 2012
          • 1129
          Ah didn't realize it came that way.
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            I wish you well. Last month i had a 350 that started doing that. We literally rebuilt the whole thing. Every board, hopper, erase lamp, power supply. Nothing worked. The machine was due to be replaced, and the new one was delivered while service manager was changing power supply. We sent it back to lease company, still broke. Would love to know what fixes it.
            • Hansoon
              • Sep 2007
              • 3381
              Solution ID TAUS0808236EN* Solution Usage 0
              Description
              What can cause the machine to intermittently display a C-2557 code even after the Imaging Unit and PWB-A have been replaced?
              Solution
              The machinemay intermittently display a C-2557 code even after the Imaging Unit and PWB-A have been replaced if the cooling fan M5 is starting to fail.
              Please replace cooling fan M5 (p/n 9313-1100-33).
              SPECIAL NOTE: Solution contribution by Dave Bruni, Workgroup/SSD
              Hans
              • wseyller
                • Sep 2012
                • 1129
                Nice find Hansoon. That will be one of the parts I grab from a spare parts machine.
                • rrrohan
                  • Sep 2011
                  • 1977
                  Had this during training today. Techj didn't screw in the 2 screws after removing drum and dev
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    Have you checked the toner adding solenoid as per my post;
                    http://www.copytechnet.com/forums/ko...highlight=2557
                    When it gets stuck open you will get 2557's intermittently as toner is added uncontrollably. Even if it isnt stuck open, operate it and see if the foam is sticky in the open position. if it does not release instantly you have a problem.
                    • wseyller
                      • Sep 2012
                      • 1129
                      OK I have it fixed I believe. I tried a 2nd IU and it does not code out right away. This was the same behavior as the 1st. But after running F8 you get C255C. Then after that it always codes right way with C2557 after trouble reset. So I replaced the pwb-a board but it still codes out right away after trouble reset. I then try the M5 cooling fan as well but no change. Then I try a 3rd IU and it then worked with no problem. Im wondering if the board was damaging the TCR sensor.
                        • 23006
                        That was a costly fix on an old POS. =^..^=
                        • richwalker
                          • Mar 2013
                          • 30
                          I agree with EarthKMTech, check the toner adding solenoid to ensure it's not sticking in the open position. If it is, then clean it and replace developer and run F8 again.
                          Richwalker.
                          • wseyller
                            • Sep 2012
                            • 1129
                            Well the problem came back. Going the shop now the get the more parts that were suggested.
                            • wseyller
                              • Sep 2012
                              • 1129
                              EarthKMTech hit the nail on the head. That solenoid was stuck open. I removed it and cleaned. Replaced dev and run F8. Feel confident that should do it hopefully.
